1986 Toyota Tercel WATER PUMP ENGINE MOUNT
1986 TOYOTA TERCEL
200,000 MILES • 4 CYL • 4WD • AUTOMATIC
WESA98
I broke one of the bolts that the water pump attaches to the motor by.Were can I find this part?
Dec 3, 2008 at 4:14 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:3851f7d38e="wesa98"]Engine Cooling problem
1986 Toyota Tercel 4 cyl Four Wheel Drive Automatic 200000 miles
I broke one of the bolts that the water pump attaches to the motor by.Were can I find this part?[/quote:3851f7d38e]
Did you get the rest of the bolt out? If so you can take both pieces and get a length (in Milimeters). Go but your local auto parts store they should be able to find the thread pitch and diameter. It won't be original and you may need to use a washer or 2 but the bolt will work just fine.
Dec 3, 2008 at 4:25 AM
