1985 Toyota Tercel Temp Gauge High
E-TOYOTA
I just recently purchased a '85 Tercel that is in pretty good condition - it is an automatic with around 236,000 kilometers on it. I was driving it around today, and noticed that the temperature gauge is slightly high (below the 'warning' lines, but a bit higher then the middle). I know from new Toyotas that the temperature gauge should be in the middle, but this was slighter higher then that. I checked the coolant (level okay) rad, (enough water) and the oil should be changed within the next week or so. Does anyone know from experience if this is a normal temperature level reading, and if not, can anyone suggest what my next move would be? Would the rad need to be flushed, or would it be a problem with the water pump? It's frustrating, b/c I didn't spend a lot on the vehicle, in hopes that it might last me a few months without major problems (student car!) and really don't have much left for repairs. If there are any suggestions or comments, I would really appreaciate any help. Thank you so much.
Apr 11, 2007 at 6:34 PM
  • 75,988 POSTS
[quote:ecb0397988="E-toyota"]Hello,
rad need to be flushed, or would it be a problem with the water pump? It's frustrating, b/c I didn't spend a lot on the vehicle, in hopes that it might last me a few months without major problems (student car!) and really don't have much left for repairs. If there are any suggestions or comments, I would really appreaciate any help. Thank you so much.[/quote:ecb0397988]
Start by changing the thermostat and comeback
Apr 11, 2007 at 7:25 PM
Suggested Repair
Start by replacing the thermostat, then recheck the temperature gauge and report back if it is still high.
Conversation Summary
The owner of a 1985 Toyota Tercel automatic with about 236,000 km noticed the temperature gauge running slightly above the middle but below the warning range. Coolant level appeared okay. The expert advised starting by changing the thermostat and following up afterward.
