1993 Toyota Tercel Radio Fuse Blows
TOYOTA
AARP
i have a 1993 totoyta turcel and i have an aftermarket stereo in it i worked fine till i went to plug in a neon strip into the outlet the fuse blow i unplugged the neon and ten changed the fuse (but several times) cause now it blows that fuse everytime i go to start the car
Oct 31, 2007 at 7:29 AM
  • 75,988 POSTS
Your ignition switch power on the radio is shorted out. You need to open it up and inspect for melted wires
Oct 31, 2007 at 7:45 AM
BEAST69E
when i take the head unit out to check for melted wires if there are melted wires what do i do?
Oct 31, 2007 at 12:14 PM
  • 75,988 POSTS
What fuse is blowing? the unit ot its original designed for the radio/accessories for the sound system. If its blowing the fuse that's part of the aftermarket component check the wiring to it.
Oct 31, 2007 at 1:47 PM
Suggested Repair
Inspect the radio ignition-switched power circuit for a short and melted wires. Determine whether the blown fuse belongs to the aftermarket stereo or the factory radio/accessory circuit, then check and repair the related wiring.
Conversation Summary
A 1993 Toyota Tercel with an aftermarket stereo began blowing a fuse after a neon light strip was plugged into an outlet. Replacing the fuse did not help, and it now blows whenever the car is started. The expert said the radio's ignition power circuit is likely shorted and advised opening the unit to inspect for melted wires, then identifying which fuse is blowing and checking the related wiring.
