HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Tacoma
Engine
Symptoms
Not Running
1998 Toyota Tacoma Click but won't start
DRREALTOR
MEMBER
1998 TOYOTA TACOMA
4 CYL
4WD
MANUAL
78,000 MILES
My 1998 Tocoma clicks when you try to start it, It clicks about 4 or 5 times then starts. What is wrong with it.
Monday, August 17th, 2009 AT 3:48 PM
MECHANIC
Hi there,
I would be getting the starter o/hauled as the main contacts in the solinoid are faulty, this is the first thing that normally wears out on starters.
Mark (mhpautos)
SPONSORED LINKS
Monday, August 17th, 2009 AT 5:29 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Cranks But Does Not Start Until 2-3 Attempts Are Made...
1998 Toyota Tacoma 2.4 Engine, 155,000 Miles. Starts Fine When Cold. After Running 2 - 3 Short Errands It Will Crank But Not Fire Until 2-3...
Asked by
joesdiner
1998
TOYOTA TACOMA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1998 Toyota Tacoma Car Won;t Start
I Changed The Battery And The Pick Up Will Crank But Wont Start. I Thought It Was The Fuel Pump And Put Some Ignition Fluid On The Intake...
Asked by
robogar
1998
TOYOTA TACOMA
What Could Be The Cause Of My Truck Not Starting...
Here Is Some Background On The Issue. I Bought This Truck About 2 Months Ago. After Having It For A Couple Of Weeks, It Began To Not Turn...
Asked by
rh.phillips
1998
TOYOTA TACOMA
I'm Having Starting Issues With My Truck After It Is...
I'm Having Starting Issues With My Truck After It Is Warm. If I Kill The Engine And Start It Back Up Within 10 Min Or So It Fires Right Up....
Asked by
Jmyers224
1998
TOYOTA TACOMA
1999 Toyota Tacoma Truck Won't Start.
Engine Mechanical Problem 1999 Toyota Tacoma 6 Cyl Four Wheel Drive Automatic Truck Is A 6 Cyl 4 Wheel Drive Automatic, It Recently...
Asked by
chinnie
1999
TOYOTA TACOMA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
