1993 Toyota T-100 Starting
1993 TOYOTA T-100
93,000 MILES • 6 CYL • 4WD • MANUAL
ADKMEHRMAN
My truck will not start. Pulled plugs to check if getting spark and low and behold no spark. Checked distibutor cap and saw no issues. Pulled the wire going from the coil to distrubutor and turned engine over to see if there was any spark coming from the coil, and nope no spark. So I replaced the coil and still no spark. I am running out of ides.
May 26, 2009 at 9:55 AM
Do you have battery voltage on the coil positive terminal if so check the distributor pick-up coil if okay next major item on line is the ignitor-also check ignition fuse
The computer has to see an Ne and G signals in order for the computer to give Igt signal to the ignitor to fire the coil and an Igf signal telling the computer that ignition has occur-this cycle repeats continously
May 26, 2009 at 10:08 AM
