1989 Toyota Supra Cylinder heads
1989 TOYOTA SUPRA
QUESTIONMARK364
Engine Mechanical problem
1989 Toyota Supra Automatic 95,000 miles
I bought a 1989 Toyota Supra Turbo from a guy. He says it just need a new heads and all good to go, car body, seats every thing in good Con. so he had took off the Cylinder heads to know which kind to get from a used part yard. ( twin Cam. shaft, 6 cyl. straight block). well he forget to cover the engine after taking off for a couple of days moisture under hood gets litte water in the cylder block not much but the heads Lock up so im Told. is there anything i can do to Unlock them or im just lookin to get a whole new Engine or block?
Apr 8, 2009 at 10:04 AM
  • 31,937 POSTS
Hi there,
If it is just a little surface moisture, give the bores a good soaking with oil or a penetrating spray, the engine should turn easily with out the head on, just start rocking the engine a little to start it moving, if there is any rust marks in the bore you will need a mechanic to inspect this first hand to make an assessment of any damage done.
mark (mhpautos)
Apr 8, 2009 at 1:32 PM
