2002 Toyota Solara Engine lacks power
193,000 MILES • 4 CYL • FWD • AUTOMATIC
LIGHTENIN77
The engine lacks power and will not go over 60mph
Aug 19, 2010 at 3:43 AM
  • 75,988 POSTS
Start here-inspect and test all the items below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Aug 19, 2010 at 9:15 AM
