Thanks!
Kevin
Prioritize the P1155 A/F sensor heater circuit. Confirm the heater has proper voltage and about 2 amps, and check heater resistance with a DVOM before replacing a sensor. Also scan the upstream bank 1 and bank 2 A/F sensors and the downstream oxygen sensor, and check for vacuum or EGR leaks, excessive fuel pressure, and sensor contamination. One code can cause the other, so do not replace parts until testing confirms the fault.
A 2001 Toyota Sienna failed emissions with P1130 (A/F sensor circuit range/performance) and P1155 (A/F sensor heater circuit). The owner wanted to know whether both codes pointed to one sensor and whether replacement was necessary. Experts said the heater-circuit code was more concerning and that one code can cause the other. They explained the upstream A/F sensors and downstream oxygen sensor, and recommended checking heater voltage and resistance, sensor signals, vacuum and EGR leaks, fuel pressure, and contamination before replacing parts.
