2002 Toyota Sienna Low Idle Stall
GRAMOS2000
Got a 2002 Toyota Sienna, about 60000 miles. Once in a while, I would start my van and it would start off and idle very low and the engine would eventually stall. I'd try this over and over until it eventually starts off and idle normally. Any idea what this may be?
Mar 1, 2006 at 4:05 PM
  • 55,616 POSTS
First, check for vacuum leaks, if ok, check the mass air flow sensor. We have replaced many on that car. Also Scan your PCM for trouble codes.
Mar 10, 2006 at 10:01 AM
LOSTINMARS
  • 222 POSTS
i know this is old but justed wanted to comment.
the idle air control valve on these engines get stuck and cause this problem.
Nov 3, 2007 at 6:21 PM
  • 55,616 POSTS
Good call, I have seen that before also. Just forgot to mention it.
Nov 5, 2007 at 1:43 AM
Suggested Repair
Check for vacuum leaks and scan the PCM for trouble codes. If no leaks are found, inspect the mass air flow sensor and the idle air control valve, which can stick and cause a very low idle and stalling.
Conversation Summary
A 2002 Toyota Sienna with about 60,000 miles occasionally starts with a very low idle and then stalls, but eventually starts and idles normally after repeated attempts. Experts recommend checking for vacuum leaks, scanning for trouble codes, and inspecting the mass air flow sensor. Another expert notes that a sticking idle air control valve can cause this problem, and that suggestion was confirmed as a known issue.
