How expensive might it be to fix/replace the drive shaft in my 1996 toyota Rav4?
Feb 5, 2007 at 4:47 PM
Inspect the driveshaft U-joint, which best fits a clunk when shifting into gear with the brake applied. Also check the center or carrier bearing if the shaft is two-piece. A shop repair was estimated at roughly a couple hundred dollars; DIY parts may cost less.
The owner of a 1996 Toyota RAV4 with 131,000 miles reported a thunk and jolt when lifting off the gas, mostly in second gear, plus a clunk from the rear center when first putting the vehicle in gear. Experts said a bad driveshaft more often causes vibration and is not commonly replaced. They suspected a worn U-joint and also suggested checking a center or carrier bearing, with a rough cost of a couple hundred dollars.
