97 rav4 long crank
SONG7
109,000 miles 4 cyl.
just got my timing belt replace ever since then it takes a little bit longer to crank. what kind it be? also its been about 2yrs since i had sparks plugs replace. can that be the problem..
Sep 29, 2007 at 6:34 PM
BMRFIXIT
  • 19,053 POSTS
[quote:7b8138b516="song7"]109,000 miles 4 cyl.
just got my timing belt replace ever since then it takes a little bit longer to crank. what kind it be? also its been about 2yrs since i had sparks plugs replace. can that be the problem..[/quote:7b8138b516]
A good tune up may be needed !
check fuel pressure /fuel filter
good luck
let us know
Sep 30, 2007 at 12:03 AM
BUZZSAW
  • 1,198 POSTS
[quote:bbd5475f98="song7"]109,000 miles 4 cyl.
just got my timing belt replace ever since then it takes a little bit longer to crank. what kind it be? also its been about 2yrs since i had sparks plugs replace. can that be the problem..[/quote:bbd5475f98]
is prob first thing in the morning? cold start injector may be prob
Sep 30, 2007 at 10:28 PM
