Toyota Previa
TOYOTA PREVIA
CRABBIEME
Hello. I have a 1992 Toyota Previa. The oil lamp came on after an oil change. I was driving and the light blinked three times and the engine (I believe) popped and there was a flash. I quickly turned of the engine. What happened? Can I turn it back on? Could it be the engine oil feeder system failed? Is my engine shot? Help, I really love this car. It has been very dependable.
Thanks
Tony :shock:
May 27, 2007 at 1:33 PM
[quote:88fd898365="crabbieme"]Hello. I have a 1992 Toyota Previa. The oil lamp came on after an oil change. I was driving and the light blinked three times and the engine (I believe) popped and there was a flash. I quickly turned of the engine. What happened? Can I turn it back on? Could it be the engine oil feeder system failed? Is my engine shot? Help, I really love this car. It has been very dependable.
Thanks
Tony :shock:[/quote:88fd898365]
Could it be the engine oil feeder system failed? could be.There's a relay for it-look at the cover similar to the EFI relay.
Okay about the oil light -clear it by remove the EFI fuse for 10secs or better.
I have a 95 I don't even use the 2qts container or the engine oil feeder-I took the relay out.Just be checking the oil thru under the driver seat.
Hope this helps -Good Luck
May 27, 2007 at 3:18 PM
