The engine management light has come on, I have changed the lambda sensor but the light is still on. There is also a 'pinging noise' and the exhaust smells 'rich'. The car has also started to idle when I am pulling away. What could the problem be? As I have already changed the lambda sensor, which I was told was the cause, I am lost as too where to look now. Thank you.
SPONSORED LINKS
Wednesday, June 11th, 2008 AT 3:50 PM
