1997 Toyota Previa Check Engine Light
1997 TOYOTA PREVIA
OZ1099
1997 Toyota Previa 4 cyl Two Wheel Drive Automatic 145k miles
Is there a way to retrieve the obd code from this vehicle without a scan tool? Jumper between the obd connector points or a key on/off procedure causing the mil light to flash the code?
Mar 7, 2010 at 3:28 AM
OZ1099
Yes oz as a matter of fact you can. There is a obdI style connector under the driver seat. If you jump the TE1 port and the E1 port this will cause your oil light to flash the codes! Good Luck!
Mar 10, 2010 at 9:06 AM
