1986 Toyota Previa
CHRIS EBADAN
  • 1986 TOYOTA PREVIA
  • 4 CYL
  • 4WD
  • 220,000 MILES
THE CAR SMELLS AS IF SOMETHING IS BURNING LIKE WHEN THE GASKET IS BURNT WHEN I DRIVE FOR ABT AN HOUR OR MORE BUT THE TEMP DOES NOT RISE AND THERE IS WATER IN THE RADIATOR. ALSO IT DOES NOT START AT ONCE AND SOMETIMES JUMP WHEB I ENGAGE THE GEAR THE FIRST TIME
Wednesday, April 23rd, 2008 AT 5:36 AM
What 86 Previa- I thought it came out in 91 and replaced by its sister Sienna 98. Okay open up the passenger seat and check the valve cover and also the distributor normally it will leak at this 2 points. Also inspect your oil container line at the front right.
Wednesday, April 23rd, 2008 AT 5:56 AM
