1994 Toyota Pickup Power Loss
FERGUSO5
I have a 1994 2WD 4 cylinder toyota truck with 159000miles and have recently experienced a severe power reduction. It happened quite suddenly, and seems like it is a timing problem. The truck starts and will idle rough at 1200rpm, but when it warms up and reduces the idling to 500 rpm it will choke and die. I took it to a mechanic and he said that it had a worn timing chain that needed to be replaced, but I am pretty sure that he did not open the head and take a look at the chain. I did open the head cover and looked at the chain and it appeared fine (although I don't have experience in diagnosing a worn chain, it was tensioned and looked new and I cannot imagine that it could "slip"). I have taken the truck in for a tune up before and had the timing reset, but it has never been this bad. I now know a bit more about the truck and can fix most simple things myself, so I am planning on changing the distributor cap and rotor and the wires, reset the timing, and see how it goes, but I am afraid that it is more than a timing problem. Any suggestions?
Jul 10, 2007 at 8:35 AM
2CARPRO JACK
  • 11,533 POSTS
Is the Check Engine Light on? Does the engine rattle excessivly on start up? You can try loosening the exhaust at the flange before the cat converter and drive it (a little loud) but it will rule out a plugged exhaust
Jul 11, 2007 at 12:51 AM
FERGUSO5
The light is not on. It does indeed rattle upon startup. I will try what you said and see how it goes.
I saw this topic on the forum and it makes me think that it may be the timing chain:
https://www.2carpros.com/forum/viewtopic.php?p=99684
His symptoms seem quite like mine. If the timing chain skipped, can it be fixed by resetting the timing?
Jul 11, 2007 at 3:43 AM
2CARPRO JACK
  • 11,533 POSTS
If the chain jumped, it is because the tensioner, tensioner shoe, and chain guides are worn out, common for Toyota's after the mileage gets up there
Jul 12, 2007 at 12:55 AM
Suggested Repair
Rule out a plugged exhaust by loosening the flange before the catalytic converter and test-driving. Startup rattle and sudden power loss also point to a jumped timing chain from worn tensioner, tensioner shoe, and chain guides, which are common on high-mileage Toyotas and should be replaced rather than only resetting timing.
Conversation Summary
A 1994 Toyota Pickup with about 159,000 miles suddenly lost power, idled roughly, and died as it warmed. The check engine light was off, but the engine rattled on startup. A shop blamed a worn timing chain without opening the cover; the owner saw a tensioned chain and planned a cap, rotor, wires, and timing reset. The expert suggested a temporary exhaust-flange test to rule out a plugged converter and said a jumped chain is typically caused by worn tensioner, shoe, and guides.
