1997 Toyota Tercel Inconsistent Start
KATMEEK
Tercel CE 1997, 125,000 miles, 4 cl Been starting inconsistently. The first time, thougt it was battery and got a jump but that wasn't it. Then I tried starting the car again, and it started up. My guess it is the clutch, as on a Toyota truck, if the clutch is not engaged all the way to the floor, it will not start. But then it started to turn on, but not start, so now I think it is the ignigition switch?? I would like some kind of answer before taking it in to the dealer to get fixed so they don't SNOW me, or ripp me off! Thank you for your help!
Apr 30, 2007 at 3:17 PM
  • 75,988 POSTS
[quote:570ab073a4="katmeek"]Tercel CE 1997, 125,000 miles, 4 cl Been starting inconsistently. The first time, thougt it was battery and got a jump but that wasn't it. Then I tried starting the car again, and it started up. My guess it is the clutch, as on a Toyota truck, if the clutch is not engaged all the way to the floor, it will not start. But then it started to turn on, but not start, so now I think it is the ignigition switch?? I would like some kind of answer before taking it in to the dealer to get fixed so they don't SNOW me, or ripp me off! Thank you for your help![/quote:570ab073a4]
Could be the I/switch,Clutch switch, starter relay and starter-having a clutch problem will not prevent it from starting-meaning it will crank and start w/o the clutch
May 1, 2007 at 7:30 AM
Suggested Repair
Check the ignition switch, clutch safety switch, starter relay, and starter. A mechanical clutch problem will not prevent the engine from cranking and starting.
Conversation Summary
The owner of a 1997 Toyota Tercel reports intermittent starting. A jump start did not solve it, and the owner suspected the clutch interlock or ignition switch. The expert says the ignition switch, clutch switch, starter relay, and starter are possible causes, and notes that a clutch problem will not stop the engine from cranking and starting.
