1988 Toyota Sunrader Driveline Vibration
MCSHANK
'88 Toyota Sunrader RV 21'
22R-E A43D trans 110,000 miles
At speeds over 55 mph there is a heavy vibration in driveline. Doesn't happen at all speeds, but rather depending on how much gas I give it. Mostly when climbing slight grades, disappears with gas pedal to the floor - reapperas with a little less gas - goes away completely if I remove my foot from gas. Like there's a specific range of torque that gets it shaking. I've replaced carrier bearing, drive line cv's and rebalanced drive shaft. Can't tell which end its coming from, but traveling on highway causes marital unhappiness. Afraid to drive it on upcoming vacation. (I made a small donation)
Aug 27, 2007 at 10:32 AM
MERLIN2021
  • 17,250 POSTS
Have you check your rubbers?
I mean your tranny and engine mounts?
What were you thinkin?
Aug 27, 2007 at 10:38 AM
MCSHANK
Thanks Merlon for your response. I hadn't given the mounts a thought but with the mileage on this one I will. I have a mechanic who listens well and I am taking him on a vibration creating drive later this week and will direct him to inspect mounts before we go.
Aug 28, 2007 at 8:05 AM
Suggested Repair
Inspect the engine and transmission rubber mounts, which can cause torque-related driveline vibration after other driveline parts have been replaced.
Conversation Summary
A 1988 Toyota Sunrader RV with a 22R-E and A43D transmission vibrates heavily above 55 mph within a specific torque range, especially on slight grades. The vibration disappears at full throttle or when the throttle is released. The carrier bearing, driveline CVs, and driveshaft balance have already been addressed. The expert recommends checking the engine and transmission mounts, and the owner plans to have a mechanic inspect them during a test drive.
