detecting clutch problems
SHANEGUN
I own a Toyota mini-truck 4x4 - 2003 , 3.0 turbo diesel , non-intercooled, 55000 miles
I have been hearing a ticking noise when the clutch is released full while in gear or in neutral. Is this the sign of clutch failure? If so , do i need to replace the clutch disc, flywheel , pressure plate and throw-out/release bearing or can i replace individual components?
Any help would be great , Thanks
May 21, 2007 at 12:02 AM
  • 75,988 POSTS
[quote:aac040b38c="shaneGun"]I own a Toyota mini-truck 4x4 - 2003 , 3.0 turbo diesel , non-intercooled, 55000 miles
Any help would be great , Thanks[/quote:aac040b38c]
Ticking noise while clutch is fully release-something in there is on its way out-you need a clutch assy kit.
You sure its coming from the clutch assy area?
May 21, 2007 at 11:15 PM
SHANEGUN
Yes . the noise sounds like its comming from inside the bellhousing area. Ive checked it while in neutral. but is even more prevalent when cruising along slowly in 3rd or 4th. i`m sure its there for the other gears but i cant hear it clearly because of the engine and road noise on 1st and 2nd and 5th
May 21, 2007 at 11:21 PM
