1993 Toyota T100 Clutch Won't Engage
TOY100
I have a 1993 toyota T100 v6 4X4 manual trans. I just changed my clutch, slave and master cylnder. I also bled the system. I started my engine and tried to put it into gear but the gear would not engage. no gears would engage. But when i start the engine in gear and start to release the cluth, i can feel it grabbing and i'm pretty sure i can drive off, however i can not shift it into 2nd. My clutch pedal seems way loose as if there was no pressure going to the system.
Could it be possible i have a defective part somewhere?
Thanks.
Aug 2, 2007 at 11:37 AM
  • 75,988 POSTS
Try adjusting the free play and pedal height.If adjusted properly go back and recheck the M/C and Slave/Servo. Bleed the M/C than the slave. You probably still have air in it. Double check the slave.
Aug 2, 2007 at 12:58 PM
Suggested Repair
Adjust clutch pedal free play and height. If those are correct, recheck the master and slave cylinders and bleed the master first, then the slave, because air is likely still in the system. Double-check the slave cylinder.
Conversation Summary
The owner of a 1993 Toyota T100 replaced the clutch, slave cylinder, and master cylinder and bled the system, but no gears engage with the engine running and the clutch pedal feels loose. Starting in gear, the clutch seems to grab, but second gear cannot be selected. The expert advises adjusting free play and pedal height, then rechecking and bleeding the master before the slave because air is likely still present, and double-checking the slave.
