clutch sticking
TOYOTA
ELYAG0
I have a toyota 4x4 1993 It had a new clutch presser plate and throw out baring put in it about
18 mouths ago. It stated sticking and then the pedal went to the floor by its self and I had to take my hand and pull it up. could the system need bleeding?
Jul 29, 2007 at 12:25 AM
  • 31,937 POSTS
Hi there,
I would first look at the master cyl & the slave cyl and check for leaks, Have a look under the dash where the clutch master cyl is mounted for oil leaks from the rear seal, repair and or replace as req and re bleed system.
Mark (mhpautos)
Jul 31, 2007 at 5:07 PM
