Have helper Hold key in start position and look for power at the starter solenoid black/white wire power there bang on the starter if it kicks over replace the starter. No power at black/white wire check the starter relay jump female socket pin #1 and #2 and attempt to start.
No start disconnect the clutch switch at clutch pedal bracket, at the connector jump the black/red to black/white attempt to start-still no start test the ignition switch.
Wiring diagram below
SPONSORED LINKS
Monday, December 10th, 2007 AT 1:20 PM
