1995 Toyota Pickup compression test result
1995 TOYOTA PICKUP
240,000 MILES • 4 CYL • 4WD • MANUAL
PONNAPPAV
if 0 reading comes in all cylinder what could be the possible reason .what is the diagonisis process
Nov 13, 2008 at 4:50 PM
BLACKOP555
  • 10,386 POSTS
cam shaft isnt turning due to bad belt/chain or its boke.
these are very rare.
head is very loose or severly damaged
engine block is cracked in every cylinders.
all pistons have rubbed off the rings, all pistons have holes in them.
engine just isnt turning.
Nov 13, 2008 at 9:38 PM
