1994 Toyota Pickup Oxygen Sensor R&R
1994 TOYOTA PICKUP
19,300 MILES • 4 CYL • 2WD • MANUAL
ELECTRICAPPLEJUICE
For the chap who has the '95 Pickup; if he used the supplied BOSCH 4-cavity interface connector, it's quite possible that the lack of continuity is in THERE. The connector is impressive looking, but has terrible connection. Try a direct splice with soldered connections & shrink-tubing.
Now for mine - the factory apparently rounded off the 12mm nuts on my O2 sensor studs (I'm the original owner), so I get to "crack 'em off". The question... are the nuts a special type?, also - as the studs appear NOT to have threading on the exposed 1/4" (above the nuts), are they standard thread or some special threading?
Aug 4, 2009 at 8:34 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
This no thread section is just the lead in, it is a normal thread.
mark (mhpautos)
Aug 4, 2009 at 8:43 PM
  • 31,937 POSTS
The nut should just be standard R/H?T nut. The stud has this blank thread section as a lead in, there is plenty of thread below. this is a std metric thread, be it fine or coarse it will be a standard thread.
mark.
Aug 5, 2009 at 1:23 AM
