1994 Toyota Pickup throttle body
1994 TOYOTA PICKUP
94TOYO
Engine Mechanical problem
1994 Toyota Pickup 4 cyl Four Wheel Drive Manual
The truck will not start. It makes a clicking sound when the ignition is turned over. Battery is fine. A previous recommendation to someone else with the same problem was to spray the throttle body with carb spray. Where is the throttle body located?
Aug 27, 2008 at 3:41 AM
KHLOW2008
  • 41,814 POSTS
Hi 94toyo,
When you hear a clicking noise only, it has nothing to do with the throttle body.
Either the starter, its wiring circuit or battery is bad. Did you test the battery voltage? Does jumping with another battery cranks the engine?
Sep 13, 2008 at 2:56 AM
94TOYO
Thank you, KHLow2008.
It was the starter.
Sep 13, 2008 at 4:47 AM
