Hi there,
I would say that there is a problem with the internals of the transmission, I have had there gearboxes strip teeth from the input shaft and loose drive to the lay shaft, 4th is straight through the main shaft with out drive through the lay shaft, was there any problems with noise or gear selection prior to this? Drain the oil and check for metal
mark (mhpautos)
SPONSORED LINKS
Saturday, April 24th, 2010 AT 9:24 PM
