1989 Toyota Pickup won't go over 2000 RPM
YAPPERSEUS
  • 1989 TOYOTA PICKUP
  • 4 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
my truck starts fine. Idles fine. But once I step on the gas and get to 2000 rpm. It seems as if I am running out of gas? I have replaced the fuel pump. Fuel pump relay. And temperature sensors.
last year I replaced both oxygen sensors? Could it be my cataltic converter?
ronnie
arizona
Wednesday, June 4th, 2008 AT 3:00 PM
HILLBILLY JIM
  • 12 POSTS
Check your exhaust to see if it hot at an idle. If so the cat is plugged up. Have you replaced the fuel filter. It is on the left side of the block right above the oil filter.
Last year I replaced both oxygen sensors? Could it be my cataltic converter?
Ronnie
arizona[/quote]
Wednesday, June 4th, 2008 AT 10:34 PM
YAPPERSEUS
Yes I have also changed the fiter.
Tuesday, June 10th, 2008 AT 10:33 AM
YAPPERSEUS
Ok if there is no more help on this I will close the thrend? Thanks to thoses who trie to help.
Problem is still there.
Friday, June 20th, 2008 AT 9:21 PM
YAPPERSEUS
Ok, I will end this tread with the answer.
After replacing everything on the fuel system.
The last thing I replaced was the fuel regulator.
My truck runs fine.
Tuesday, June 24th, 2008 AT 3:47 PM
