1992 Toyota Pickup Engine wont start
BKS
  • 1992 TOYOTA PICKUP
1992 Toyota Pickup Manual
I have a 1992 toyota that wont start. It started earlier this morning and wont start up again. I have tried jumping it and that didn't work. Can you please offer some suggestions?
Thanks
Tuesday, January 20th, 2009 AT 5:03 PM
Do below to determine if its fuel or spark problem then get back
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Tuesday, January 20th, 2009 AT 5:06 PM
