1990 Toyota Pickup truck wont start
RAYMOND82
  • 1990 TOYOTA PICKUP
Electrical problem
1990 Toyota Pickup 4 cyl Two Wheel Drive Manual? Miles
my toyota truck has ran graet for years. Two weeks ago it was raining and just stoped and will not start agen. Iv checked every thing. It gets gas it has good compretion the timing chain is good and seams to get descent spark. So if gets spark and fuel and has good compretion why wont it start
Sunday, June 1st, 2008 AT 2:36 PM
Could be wrong valve and ignition timing or an incorrect fuel pressure.
Sunday, June 1st, 2008 AT 2:54 PM
HILLBILLY JIM
  • 12 POSTS
Your distributor is either wet or cracked or both and the electronic componets inside the distributor is wet. A phillips screwdriver and a hair dryer are all you need
my toyota truck has ran graet for years. Two weeks ago it was raining and just stoped and will not start agen. Iv checked every thing. It gets gas it has good compretion the timing chain is good and seams to get descent spark. So if gets spark and fuel and has good compretion why wont it start[/quote]
Wednesday, June 4th, 2008 AT 9:00 PM
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Wednesday, June 4th, 2008 AT 11:26 PM
