1990 Toyota Pickup Slow Acceleration
EDTS13
Hi, I have a automatic 1990 toyota pickup. It has a 22RE engine and is a 4x4 with 193,000 miles. I've kept it in great shape but recently ran into an issue I can't figure out. Once 6 months ago, I pulled to a stop and started to accelerate again but the car was moving very slowly. It's similar to having your brake engaged when you step on the gas. I have to press down hard before it starts moving and then it's fine. this past week, the same thing occured again when I pulled to a stop light. It doesn't happen everytime though. I did notice that while I was trying to speed up, the O/D (overdrive) light flickered slowly a couple times. It stopped after everything was back to normal. I checked my engine and didn't see any leaks or anything abnormal. Any idea what the problem might be? Thanks.
Jun 30, 2007 at 9:45 AM
2CARPRO JACK
  • 11,533 POSTS
Could be the trans having a problem. If the OD light comes on it is usually a sign of the ECM not being happy with something or it is seeing a problem somewhere. Might want to have a trans shop do a diagnostic just to be safe
Jul 1, 2007 at 1:36 AM
Suggested Repair
Have a transmission shop diagnose the transmission and related ECM signals. The flickering overdrive light often indicates the ECM is detecting a problem, and the intermittent slow takeoff after a stop may be transmission-related.
Conversation Summary
The owner of a 1990 Toyota Pickup with a 22RE automatic and 4x4 reports intermittent slow initial acceleration after stopping, as if the brakes were engaged, followed by normal driving once it gets moving. The overdrive light flickered during one episode, and no leaks or obvious engine problems were found. The expert says the transmission may be at fault and that the overdrive light usually means the ECM is detecting a problem, so a transmission shop should perform a diagnostic.
