Trouble code 52
RUSSELL911
  • 1990 TOYOTA PICKUP
  • 4 CYL
  • 120,000 MILES
What is a code 52?
Tuesday, January 22nd, 2008 AT 4:02 PM
HEATH HUNTER
Code 52 is knock sensor signal. There's 2 codes with that description, so I'm still trying to get more detailed description of it, but figured I would just throw that out there for everyone.
Saturday, December 31st, 2016 AT 11:23 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,307 POSTS
Hey HEATH,
Yes a code 52 is a knock sensor, We have tried replacing the sensor with some luck. Also replace the wire lead to the sensor as well.
This code can be set when the engine gets excessive mileage on it and the clearances become out of tolerance so the sensor hears internal knocking noise and cant control it which in turn give you the code.
Please let us know happens so it will help others.
Best, Ken
Wednesday, January 4th, 2017 AT 11:39 AM
