1988 Toyota Pickup OVERHEATING
MGROSZ7M
  • 1988 TOYOTA PICKUP
Other Category problem
1988 Toyota Pickup 4 cyl Wheel Drive Type unknown Manual 230, 00 miles
WAS IMFORMED BY MECHANIC SMALL CRACK IN HEADGASKET HAVE A LEAK IN FRONT OIL SEAL ALREADY HAD COMPRESSION CHECK LOW COMPRESSION ONE CYLINDER BLOCK OKAY; NO WATER IN OIL NO STEAM OR WATER FROM TAILPIPE. REPLACED THERMOSTAT MONTH AGO STILL GET OVERHEATING PROBLEM DAYTIME ONLY NOT AT NIGHT ANY SUGGESTIONS; DRAINED WATER TWO DAYS AGO ADDED NEW ANTIFREEZE DRIVE FOR HALF HOUR GETS TO TOP OF WHITE LINE 1/2 INCH FROM RED ZONE.
Monday, February 11th, 2008 AT 3:02 AM
Did he replaced the headgasket and also find out what causing that cylinder to be low in compression. Seems to me you have a combustion gas leakage.
Get it block and pressure tested. BTW did you bleed the cooling system? Could be air lock in it.
Monday, February 11th, 2008 AT 3:29 AM
