1987 Toyota Pickup truck want start
1987 TOYOTA PICKUP
BABEINBLUEJEANS
Engine Mechanical problem
1987 Toyota Pickup 4 cyl Two Wheel Drive Automatic
a friend has a 1987 automatic toyota pickup. The other night the lights started going dim. She parked it. The next moringin it would not start or do anything. Tried to jump it off, recharge battery,replace alternator. Still want do anything. Just lights will come on. Nothing when switch is turned. Can hear a click under the hood but that is all.
Jul 26, 2010 at 9:47 AM
No crank at all/nothing/nada:
Could be the starter,starter relay,park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Jul 26, 2010 at 12:38 PM
