1986 Toyota Pickup Speedometer not funtioning correctly
246,000 MILES • 4 CYL • 2WD • MANUAL
JONNYBOY18
  • 5 POSTS
When you are not moving the speedometer sets between 10 and 15mph. So while I am driving I have to kinda estimate how fast I am going by subtracting about 10 or so mph off. And once the speedometer gets to 70mph and over it wobbles. I am just wondering what may be causing this and if there is any easy way to fix this.
Aug 25, 2010 at 3:49 PM
  • 75,988 POSTS
If its cable driven inspect both ends/speedo head, if electronic check the vehicle speed sensor.
Aug 25, 2010 at 5:31 PM
JONNYBOY18
  • 5 POSTS
How would I be able to tell if it is cable driven or electronic?
Aug 26, 2010 at 12:32 PM
  • 75,988 POSTS
Check the speedometer driven gear on the transmission if ok there,check behind the speedometer.
Aug 26, 2010 at 12:49 PM
