1986 Toyota Pickup 4 cyl Two Wheel Drive Manual 200 + miles
HI, My Toyota truck W/ 200,000+ Miles, oil leaks and all, now has a overheating problem?
I fill the radiator and with in 20 miles or so it starts overheating and the radiator fluid disapppears but don't see any major leaks or puddles any where, My question is:
Is it the THERMOSTAT
or/ WATER PUMP,
I'm unsure what I should try first or what my symptoms mean.
The haeter also gets hotter & hotter as it overheats, I have put in two kinds of radiator stop leak, the first time worked for almost a month but I'm thinking its not a leaking problem,
So again with my symptons, (Overheatong and loss of radiator fluid) could it be the THERMOSTAT -OR- WATER PUMP?
NOTE: just saw the donation option Iam unable to donate at this time plus I would like to see what this site is about first, but if all seems legiate, I will have no problems giving a donation.
Thank You CURT
SPONSORED LINKS
Sunday, December 7th, 2008 AT 1:01 AM
