1986 Toyota Pickup
PGUANACO
  • 1986 TOYOTA PICKUP
Other Category problem
1986 Toyota Pickup 4 cyl Front Wheel Drive 289700 miles
This is an old truck that I only use on the sumer to haul stuff, the problem i'm having is tha in the past 3 year I have to change the batery about 3 times. Aster a while of being park during the winter the batery does not recharge any more.
thank you.
Pedro from Seattle Wa
Wednesday, February 13th, 2008 AT 6:22 AM
Get the battery load tested if it passes it -you probably have an electrical short somewhere in the electrical system. Try the test below
Get a test light and disconnect the negative battery cable now put the light between the cable and battery negative post is the light On? If so start removing fuses one at a time -the fuse that turns off the light is the trouble circuit. Then break out the electrical wiring diagram.
In the event you removed all the fuses and the light is still On disconnect the alternator batt. Feed and the connector-if this one turns off the light-the alternator has bad diodes.
Wednesday, February 13th, 2008 AT 6:28 AM
