Electrical problem
1984 Toyota Pickup 4 cyl Four Wheel Drive Automatic
is there a way to check crank sensor?If it good any other advice to figure out why it don't deliver gas?
Friday, November 5th, 2010 AT 6:13 PM
MECHANIC
Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
