1993 Toyota Paseo Acceleration Problem
99,999 MILES • 4 CYL • FWD • MANUAL
M1KE818F1NEST
My Car for some reason does not accelerate. it will get up to speed well enough to drive around, but for some reason it feels like it doesnt have its true potential till it goes over the 3 rev. I've changed the spark plugs, spark plug wires, distributor cap, rotor inside the distributor cap, fuel filter, clutch. I know everything works on the car because I just changed the engine and was working fine with my other engine let it R.I.P. So I am stuck not knowing what to do next...
Oct 11, 2010 at 5:33 AM
DSPLC
  • 220 POSTS
Did you check your timing mark. It should be 10 degrees (BTDC) Before top dead center at idle (600 to 750 RPM). Then, when you rev up a little, it goes to 20+ degrees BTDC.
Oct 11, 2010 at 7:59 AM
M1KE818F1NEST
Thank you thank you don't know how grateful I am my car works great now
Oct 15, 2010 at 11:03 AM
