Totya Turcel
TOYOTA
AARP
i have a 1993 totoyta turcel and i have an aftermarket stereo in it i worked fine till i went to plug in a neon strip into the outlet the fuse blow i unplugged the neon and ten changed the fuse (but several times) cause now it blows that fuse everytime i go to start the car
Oct 31, 2007 at 7:29 AM
  • 75,988 POSTS
Your ignition switch power on the radio is shorted out. You need to open it up and inspect for melted wires
Oct 31, 2007 at 7:45 AM
BEAST69E
when i take the head unit out to check for melted wires if there are melted wires what do i do?
Oct 31, 2007 at 12:14 PM
  • 75,988 POSTS
What fuse is blowing? the unit ot its original designed for the radio/accessories for the sound system. If its blowing the fuse that's part of the aftermarket component check the wiring to it.
Oct 31, 2007 at 1:47 PM
