1995 Toyota Tacoma Overheating
TOYOTA
MS48
i have a 1995 toy sr5 tacoma i just replaced the head gaskets after my heads locked down due to overheating which locked down all my lifters and locked the cams to whioch took out 7 valves in one haed and 8 in the other i put new gaskets in it after put it back together and started it it got hot again ,so i had the rad clean out new thermostat and it still gets hot i am not sure that i got the head gaskets on the right side or not ,but i took the center head off and was able to pour water thre the heads which came out the thermostat hole , have i got the head gaskets on wrong , i have new water pump ,timing belt ,thermostat ,i know its timed right because it turns over maybe twice before it starts ,and runs fine please help i am totaly lost
Apr 14, 2007 at 11:16 AM
  • 75,988 POSTS
[quote:bbbb1a975e="ms48"]i have a 1995 toy sr5 tacoma i just replaced the head gaskets after my heads locked down due to overheating which locked down all my lifters and locked the cams to whioch took out 7 valves in one haed and 8 in the other i put new gaskets in it after put it back together and started it it got hot again ,so i had the rad clean out new thermostat and it still gets hot i am not sure that i got the head gaskets on the right side or not ,but i took the center head off and was able to pour water thre the heads which came out the thermostat hole , have i got the head gaskets on wrong , i have new water pump ,timing belt ,thermostat ,i know its timed right because it turns over maybe twice before it starts ,and runs fine please help i am totaly lost[/quote:bbbb1a975e]
Did you have the heads milled/shaved?
Apr 14, 2007 at 6:09 PM
MS48
yes the heads have been completely redone ,the only thing i have not done is flush out the heater core
Apr 15, 2007 at 12:13 AM
  • 75,988 POSTS
[quote:f8f922297f="ms48"]yes the heads have been completely redone ,the only thing i have not done is flush out the heater core[/quote:f8f922297f]
The heater core won't cause the overheating problem
but i took the center head off and was able to pour water thre the heads which came out the thermostat hole , have i got the head gaskets on wrong.
The center head-you're probably talking about the intake manifold.
It suppose to come out from there to go back to the radiator. Double check all the hoses going to the radiator and resevoir end to end make sure its not plugged-up.
Check the fan clutch by doing this: start the truck up till its warmed-up, then shut it down-turn the fan by hand some drag will be present-if it freewheels easily or locked-up replace the fan clutch.
Remove the thermostat run the engine without it-overheating still present? if so put Stat back and do the above mentioned.
In conclusion if it persist-have it pressure tested to include the Rad cap.
BTW did you find out what caused the overheating to do all these damage.
Apr 15, 2007 at 1:25 AM
BESTBET777
  • 89 POSTS
Check the catalytic converter, if it's plugged up thhat can cause back pressure whhich can blow the head gasket and cause overheating.
Apr 18, 2007 at 9:50 AM
Suggested Repair
Confirm coolant hoses to the radiator and reservoir are clear end to end. Check the fan clutch after warmup (it should have drag, not freewheel or lock). Test-run without the thermostat, then pressure-test the cooling system and radiator cap. Also check for a plugged catalytic converter causing back pressure. A heater core flush is unlikely to fix overheating.
Conversation Summary
A 1995 Toyota Tacoma SR5 overheated severely, damaging valves, lifters, and cams. After head work, new head gaskets, water pump, timing belt, thermostat, and a cleaned radiator, it still overheats and runs otherwise. The owner wondered if the gaskets were installed on the wrong side after water poured through the heads came out the thermostat opening. Experts said that flow path is expected, the heater core is not the cause, and advised checking hoses, fan clutch, thermostat, system pressure and radiator cap, plus a possibly plugged catalytic converter.
