2005 Toyota Matrix Audio Power Loss
TOYOTA
SAMBURGER
2005 Toyota Matrix, 81,152 miles, v4. I was trying to install a new audio system today (two 12" subs, an amp, & a new head unit) & everything was going well until I ran out of time & had to pick my girlfriend up from school. I already had the battery wire connected to the + terminal & running to the amp & the directions I was given didn't say anything about when to connect the fuse to the wire's fuse holder (or so I thought) so I just put it in & left. Then the next thing I know, my head unit, interior lights, & clock weren't working. Did I blow the fuse? Or did I mess up my battery? What do I need to do?
Sep 4, 2007 at 1:36 PM
  • 75,988 POSTS
[quote:7417af28be="samburger"]2005 Toyota Matrix, 81,152 miles, v4. I was trying to install a new audio system today (two 12" subs, an amp, & a new head unit) & everything was going well until I ran out of time & had to pick my girlfriend up from school. I already had the battery wire connected to the + terminal & running to the amp & the directions I was given didn't say anything about when to connect the fuse to the wire's fuse holder (or so I thought) so I just put it in & left. Then the next thing I know, my head unit, interior lights, & clock weren't working. Did I blow the fuse? Or did I mess up my battery? What do I need to do?[/quote:7417af28be]
If its not a blown fuse than its not grounded right- or you fried the system
Sep 4, 2007 at 7:15 PM
Suggested Repair
Check the related fuses first. If they are intact, verify that the audio system is properly grounded; otherwise the new components may have been damaged.
Conversation Summary
The owner of a 2005 Toyota Matrix installed subs, an amplifier, and a head unit, then connected the battery power wire and fuse. Afterward, the head unit, interior lights, and clock stopped working. The expert advised checking for a blown fuse and, if the fuse is good, verifying the ground or considering that the system was damaged.
