1994 Toyota Pickup Power Loss
I saw this topic on the forum and it makes me think that it may be the timing chain:
https://www.2carpros.com/forum/viewtopic.php?p=99684
His symptoms seem quite like mine. If the timing chain skipped, can it be fixed by resetting the timing?
Suggested Repair
Rule out a plugged exhaust by loosening the flange before the catalytic converter and test-driving. Startup rattle and sudden power loss also point to a jumped timing chain from worn tensioner, tensioner shoe, and chain guides, which are common on high-mileage Toyotas and should be replaced rather than only resetting timing.
Conversation Summary
A 1994 Toyota Pickup with about 159,000 miles suddenly lost power, idled roughly, and died as it warmed. The check engine light was off, but the engine rattled on startup. A shop blamed a worn timing chain without opening the cover; the owner saw a tensioned chain and planned a cap, rotor, wires, and timing reset. The expert suggested a temporary exhaust-flange test to rule out a plugged converter and said a jumped chain is typically caused by worn tensioner, shoe, and guides.
