TIMING CHAIN
Removal
1.Remove cylinder head and oil pan.
Remove radiator, drive belts, air pump and alternator bracket. Set No. 1 cylinder to TDC of compression stroke.
Remove crankshaft pulley, water by-pass tube bolts and heater tube.
Remove timing chain cover assembly.
2.Remove chain from damper.
Remove cam sprocket and chain.
Using gear puller, remove both oil pump drive and chain sprocket.
Jan 22, 2009 at 11:45 AM
