Toyota Blown Head Gasket Sealer
TOYOTA
JREBERA1
Head gasket blown, garage losened the radiator cap which meant it runs fine, they said sell it quick.
I didn't feel I could do that. Another garage charged £50.00 and put some kind of sealer in it. The temp gauge went up and down a bit at first but has settled. Since then I have done 1500 miles and it seems fine. Is it fixed or is it just gonna blow at any moment. I am meant to be embarking on some long journeys in the summer so would like some advice. I've been told, 'if it's done over 1000 miles it fine.' Is that true.
Thanks
May 14, 2006 at 11:51 PM
LOSONE
  • 1,616 POSTS
Doing a "fix" on a head gasket is like putting a band aid on a broken arm. It will seal it for a short time but then it's going to be a lot worse like an infected arm.
It is against my old Yank principles to sell anyone a car that has problems without advising them. You have to do what you have to do.
NOW! Trading it in to a dealer is a different story as they will get a little back of what they have done to others. It's the old story "all's fair in love, war and car dealers."
Good luck!
May 17, 2006 at 10:50 AM
BLESSEDXBLOOD
I would have to agree, dont sell it to anyone, but go ahead and trade it to a dealer. I would'nt rely on that car much longer, I had the same happen to me. I eventually spun a rod bearing. NOT Pretty....haha.... good luck!!!
Sxotty :lol: :lol: :lol: :lol: :D
May 23, 2006 at 6:28 AM
Suggested Repair
Do not rely on the chemical head-gasket sealer. Have the head gasket properly repaired or replaced before any long trips, because the sealer is only a short-term patch and failure can cause worse engine damage.
Conversation Summary
The owner of a Toyota with a blown head gasket had a garage loosen the radiator cap, then paid another garage to add a chemical sealer. After about 1500 miles the temperature settled and the car seemed fine, and the owner asked whether it was safe for long summer trips. Experts said the sealer is only a temporary fix that will eventually fail and can lead to worse damage, so the car should not be relied on. They also advised against selling it privately without disclosing the problem.
