1988 Toyota Supra Blown Head Gasket
GREENMARSION
Hello
I have a toyota supra turbo 7mg te 6 twin cam 1988
its been sitting for 3 years body is mint condtion . I have blown a head gasget and the trubo is fried. Can I get a new motor with out the turbo ?
or do i have to get a new turbo?
Jun 2, 2006 at 2:03 AM
LOSONE
  • 1,616 POSTS
Sadly head gaskets on all V-6 engines were a severe problem for Totota. That issued a recall VO6 that covered most under warranty. I am not sure your engine will apply but the uses the same gasket material. Go to the beginning of the Toyota and click on the moderators comments. It will tell you about it.
You can replace the engine as long as you change the intake with out the turbo but it will reduce boost performance to 0. the negine will run the same and perform well with no shot of turbo performance.
Jun 2, 2006 at 10:21 AM
KRYPTONITEFUSION
  • 15 POSTS
u have a supra and want to replace the motor. i know this msg is old but hey...ull never know. after all u had it sitting for 3yrs. yes u can get an non turbo engine. 7mge's are inline 6 cylinder. the head gaskets are supposedly bad for many toyotas yet i never seen a problem yet.
sad to hear u had ur turbo fried. but all u need is a 7MGE motor. oppose to the supra's 7MGTE. since i've never done this or heard of doing this i would only check to see if u would also need a new transmission for this new engine. if u have an automatic u should be fine by my guess.
Feb 26, 2007 at 2:05 PM
Suggested Repair
A non-turbo 7MGE can be used in place of the turbo 7MGTE if the intake is changed for the non-turbo setup; expect no boost. Confirm transmission compatibility before swapping, and treat any Toyota head-gasket recall as uncertain for this engine.
Conversation Summary
The owner of a 1988 Toyota Supra Turbo (7MGTE) that sat for three years reports a blown head gasket and a failed turbo, and asks whether a non-turbo engine can be installed. One reply says the engine can be replaced without a turbo if the intake is changed, with no boost performance. Another reply says a 7MGE can replace the 7MGTE and that transmission fit should be checked.
