Toyota Grinding Noise When Turning
TOYOTA
BUTTERFLY
i was just wondering if you could tell me what it might be...if when you turn your steering wheel all one way like to go around a corner and it makes like a grinding noise.
thanks
May 15, 2007 at 2:55 PM
  • 75,988 POSTS
[quote:2c66762f31="butterfly"]i was just wondering if you could tell me what it might be...if when you turn your steering wheel all one way like to go around a corner and it makes like a grinding noise.
thanks[/quote:2c66762f31]
My best answer is CV Joints In/Out
May 15, 2007 at 5:50 PM
Suggested Repair
Inspect the inner and outer CV joints, which are the most likely cause of the grinding noise when the steering wheel is turned fully to one side.
Conversation Summary
The owner of a Toyota asked about a grinding noise when turning the steering wheel fully to one side, such as going around a corner. The expert's best answer was that the inner and outer CV joints are the likely cause.
