Toyota No Start When Playing With Cables
TOYOTA
GA2384
okay so for the pastweekor so my car has been acting up sometimes it will start right up and other times it wont but when it doesnt start up i play with the battery cables and i let it sit for about 5minutes and itll start right up. Today this occured again but no matter how many times i tired it wouldnt start up, somebody told me to make sure the cables were clean but i really need some advice on what to do and how to clean to cables. Thanks
May 9, 2006 at 7:05 AM
LOSONE
  • 1,616 POSTS
Remove the ground cable (-) and clean the terminal and the cable. Also remove each cable that is attached to the cable, remove and clean both ends. DON'T use soda or a liquid cleaner. Do the same for both cables. A small wire brush. pen knife or any thing to clean the surfaces and make them shiny. Good luck
May 9, 2006 at 10:21 AM
Suggested Repair
Remove and clean both battery cables, including the ground and every attached cable end. Scrape or brush the terminals and cable ends until the contact surfaces are shiny. Do not use soda or a liquid cleaner.
Conversation Summary
The owner of a Toyota reports an intermittent no-start that sometimes resolves after moving the battery cables and waiting a few minutes. An expert advises removing and cleaning both battery cables and all attached ends, including the ground, with a wire brush, pen knife, or similar tool until the surfaces are shiny, and not using soda or liquid cleaner.
