Brakes Problem
TOYOTA
DHARSHANE
hi,I have a toyota Starlet EP91 automatic. My problem is when I apply brakes the car pulls to left.I found that no brake fluid is coming to the front right cylinders. I disconnected the tube leading to the front right wheel at the ABS modulator and found that brake fluid is not coming out of it. My ABS indicator light does not stay on and ABS system operates when braking hard. Can anybody advice me what to do please?.Can there be any effect on other components iIf I revome the ABS fuse to use the car without ABS ?.
May 23, 2006 at 8:43 PM
LOSONE
  • 1,616 POSTS
If you have no fluid it is a good chance that the rubbber line to the wheel is bad.
If you disconnect the ABS the system returns to normal braking but I strongly suggest that you repair instead of disconnect.
May 26, 2006 at 10:26 AM
