1994 Toyota Hiace AC Empty After Leak
TOYOTA
JAPEE
A month ago, the air conditioning system of our Toyota Hiace Van 1994 4wd failed. The failure is cause by a leak in the system, as a result their is no more freon left in the system. It is totaly empty with Freon.
My is question is; Is it okay to add a freon back to the system after a fix the leak, or are their other components to be replace since it has been a month since the AC system has run out of freon?
Anyone who knows the answer to my question, kindly write to me. You can send me an email. My email ad is jpaliganga@gmail.com
Thank You!
Nov 6, 2007 at 12:39 PM
  • 31,937 POSTS
Hi there,
When the leak is located & repaired it would be advisable to replace the receiver/ dryer assembly, and also as the system is over 10 years old replace the compressor oil. Both these jobs are relatively inexpensive and they will both improve the reliability and overall performance of the system.
Mark (mhpautos)
Nov 16, 2007 at 2:05 PM
Suggested Repair
After the leak is located and repaired, replace the receiver/dryer and the compressor oil before recharging the system with refrigerant.
Conversation Summary
The owner of a 1994 Toyota Hiace says the air conditioning stopped a month ago because a leak emptied the refrigerant. They ask whether it is safe to recharge after fixing the leak or if other parts should be replaced. The expert advises replacing the receiver/dryer and the compressor oil because of the system's age, which should improve reliability and performance.
