1989 Toyota 4x4 Not Engaging
1989 TOYOTA
JAM
I have a 1989 Toyota 4x4 V-6 and ever since I got it back from having a new cylinder head put on, the 4x4 doesn't work. The front drive shaft and axles lock in when I put it in 4H or 4L but the indicator light doesn't come on and the front tires don't spin (except for the free-wheeling action you get in 2 wheel drive.)
Jan 21, 2007 at 5:44 AM
2CARPRO JACK
  • 11,533 POSTS
There is a wiring harness that runs down to the trans/transfer case, make sure everything is plugged in . Maybe a connector was forgotten or accidentally unplugged
Jan 22, 2007 at 8:47 AM
SURFDADDY
[quote:9467720920="jam"] Did you solve your problem with the 89 Toyota 4X4? I have similar problem with my 96 4Runner.[/quote:9467720920]
Jan 27, 2007 at 1:41 PM
Suggested Repair
Inspect the wiring harness running to the transmission and transfer case, and confirm every connector is fully plugged in. A connector may have been left disconnected during the cylinder head repair.
Conversation Summary
The owner of a 1989 Toyota 4x4 V6 says four-wheel drive stopped working after a cylinder head replacement. The front driveshaft and axles lock in 4H or 4L, but the indicator light does not come on and the front tires do not drive. The expert recommends checking that the transfer-case wiring harness and connectors are plugged in. No confirmed repair was reported.
